Can the value of an indicator be shown vertically?
I would like to show vertically the alue of an indicator (like shown in the attached file). It doesn't seem possible. I have tried clicking right but there is no access to this paramater. I have also tried using a property node but I get a message error.
I have missed something?
Thanks for your help,
User
(3,379 Views)
For the most part, that option is not "built-in". A Picture Control can be used by inserting the text with your desired orientation.
Ben
(3,376 Views)
Accepted by topic author User_1979
You could also add a caption and change the vertical arrangement to counterclockwise. Write to a Caption.Text property node.
(3,370 Views)
Hi Ben and Dennis,
Thanks for your answers. I have used the subtitle of the indicator to wright vertically and then the property node to make it show the value of the indicator. I don't know what "caption" means Dennis but it seems to be what you have told me to try.
Many thanks.
(3,339 Views)
Caption is a property of controls.  You could call it a subtitle, but the property is called "caption".
Message Edited by Ravens Fan on 02-19-2010 08:55 PM
(3,324 Views)
I know this is a really old post, but I've been looking for a way to do this as well and haven't found it. I then thought about resizing the control to appear vertical and use LabVIEW's autowrapping feature to get where I need to go. Thought I would share with the community if anyone else runs across it
-TXR
***The Best way to say 'thanks' is to hit that Kudos button!***
(2,969 Views)
