Can the M Series PCI 6221 control 24 VDC solenoid valves like the NI 9477?
I am working on a project where three solenoid valves requiring 24 VDC and 8 Watts must be controlled by a PCI 6221 multifunction DAQ.
I read on the NI website that an external power supply and the NI 9477 can be used together to actuate solenoid valves.  Since I already have the PCI 6221,
I was wondering if an external power supply would allow the PCI 6221 to power the valves.
Sincerely,
Tristram Jordan
(3,267 Views)
Hey,
No, the M-Series board only supports TTL Signals on DIO as you will find in the user manual: http://digital.ni.com/manuals.nsf/websearch/8117DF4C5A29C95C862573020061023B
Christian
(3,255 Views)
Hey,
Is there any way to control solenoid valves using the PCI 6221 DAQ card? Is it possible for the DAQ card to control a driver circuit for the valves?
If there isn't an alternate way to control the valves, which DAQ do you recommend purchasing to control 3 solenoid valves and a pressure transducer?
I am not familiar with the compactDAQ. Does the digital output module need to connect to a DAQ card within the computer? If not, how does it communicate with the computer?
Sincerely,
Tristram Jordan
(3,235 Views)
Go to www.mcmaster.com and search for part number 8299K12.  Then use a digital channel to control it.
(3,229 Views)
Hey,
You could use an 9162 Single Module Carrier with the NI 9477 C-Series Module as an example. But using cDAQ-9172 you will be more flexible and can use more than only one modul. I would suggest to call your local NI Office where you can talk to an ISR to get the best information of products regarding your constraints!
BR, Christian
(3,221 Views)
