01-15-2008 08:30 PM
01-16-2008 02:38 AM
Hey,
No, the M-Series board only supports TTL Signals on DIO as you will find in the user manual: http://digital.ni.com/manuals.nsf/websearch/8117DF4C5A29C95C862573020061023B
Christian
01-16-2008 07:16 PM
01-16-2008 07:43 PM
01-17-2008 01:17 AM
Hey,
You could use an 9162 Single Module Carrier with the NI 9477 C-Series Module as an example. But using cDAQ-9172 you will be more flexible and can use more than only one modul. I would suggest to call your local NI Office where you can talk to an ISR to get the best information of products regarding your constraints!
BR, Christian
