Can't open VI from windows to mac OS.
I have two computer, one is windows system , another in mac os.
The vi is built in windows OS, and VISA is also install in this system. I can use the “vi” file successfully.
In my mac os, I install the LABVIEW2021 community. I can open the vi file. but when I install VISA in mac, I can't open the file. And then, I unintall all the LABVIEW and VISA, and reinstall the Labview. I can't the file too.
sometimes it shows error code 3.
sometimes when I open, it will close directly.
but, in my windows system, the file can be open again.
I don't konw why.
my mac os is v12,, and the chip is M1P
(1,393 Views)
Hello PolymerL,
The problem you are facing can have various sources. It can be the difference within the bitrates of the Operating Systems, Platform-specific features, and so on.
If the VI is opening on MacOS without installing the NI-VISA you can try copying its content into a blank VI and continuing working on it.
I'm sending you links that might be helpful.
LabVIEW Load Error Code 3: Could Not Load Front Panel - NI
LabVIEW Load Error Code 3 When Running an Executable - NI
Using LabVIEW Developed VIs, Executables, or Installers with a Different Operating System - NI
Hope this will help you to solve the issue.
Best regards
(1,354 Views)
