Can't disable Maximize Button
On a customized appearance of a vi floating window
I can't find a way to disable the max button.
Enclosed is a jpeg of the look of the window.
Message 1 of 11
(5,047 Views)
usually we disable the max button by going to " VI properties->window appearence->Customize-> and de-selecting the "allow user to resize" window option.
But i see that you have customised even these button also. So curious to know how you have done that. Can you post your VI also?
Guru
Regards
Guru (CLA)
Message 2 of 11
(5,039 Views)
I use Labview 2010 SP1 and they are not customized.
Message 3 of 11
(5,037 Views)
ohh i guess then its the OS.. i am still using XP
Regards
Guru (CLA)
Message 4 of 11
(5,034 Views)
I use what NI supports. I code for and have licenses for Windows XP, Windows 7, and Macintosh.
This VI was created on the most current Mac version.
Message 5 of 11
(5,030 Views)
did you try the method suggested? it may/may not work as i am not a MAC user....
Regards
Guru (CLA)
Message 6 of 11
(5,025 Views)
I have tried that and it does not work. The floating window goes full screen, covering
everything. As an option on that dialog it appears to have been overlooked.
Message 7 of 11
(5,018 Views)
Hi Be_01880,
As Guru mentioned, setting VI properties should solve your problem. You can try and use vi property node >> FP Resizable property,
set it to false and see if maximize buttons disables or not.
Even if that does not work then you may have panel resize event, whenever you will click that, you have to set VI FP bounds to original.
I hope It will solve your problem.
Gaurav k
CLD Certified !!!!!
Do not forget to Mark solution and to give Kudo if problem is solved.
Message 8 of 11
(5,007 Views)
As I stated to Guru, this does not work. There is no option in the set "VI Properties dialog" to do this.
I have tried setting the "FP.Resizable" to false and the max button still continues to function.
Having the floating window fly open and scare the user is not acceptable.
Message 9 of 11
(4,964 Views)
There is no method currently to explicitly disable the maximize button.
Product Support Engineer
Message 10 of 11
(4,951 Views)
