01-15-2021 10:16 AM
Create LabVIEW VI feature in Visual Assistant is not working smoothly.
When I try to create a LabView VI two prompts show up for 2 different files; "Find the VI Name "nirio_FindDevices.vi" and "Find the Control Name "_nirio_device_attributes.ctl". (Screenshots included).
After cancelling both prompts, I am taken into LabView where the block diagram is locked behind a password. I have tried my passwords and none can unlock it.
Both versions of LabView and Vision Assistant are 2020 SP1.
My machine is a Ryzen 4800H 32GB RAM with Windows 10
The VI I'm trying to create is just a simple Image Display VI
I have also tried to repair both software and re-installing but the problem persists.
Can anyone please help me?
01-15-2021 11:51 AM
I am having the exact same issues....have uninstalled/reinstalled the 2020 SP1 versions (LabVIEW and Vision Development Module).
Installed 2020 versions and getting same error now??
01-15-2021 11:46 PM
Install the NI RIO driver to fix the issue.
01-18-2021 09:14 AM
Thanks, but this doesn't seem to have solved it. I installed the NI RIO 14.5 (Legacy) drivers...
I have been using Vision Assistant & LabVIEW for many years and never had these problems, just wondering if its an issue with 2020 SP1 versions.
01-18-2021 09:45 AM
NI CompactRIO install has solved the issue....
09-06-2021 02:49 AM
Compact RIO drivers installation sorted out the problem for me. But no idea what is the relationship with Compact RIO with Vision Assistant code generation.
Thanks for the suggestion.
