Can someone help
Can someone help me with these problems.
1. I have some code that plots a circle, triangle and a rectangle. I need the code to plot the three shapes onto the same graphs but can't seem to get it to work. The code is below if anyone wants to have a look and see if they can fix it.
2. The second but of code attached was advised by somone earlier on how to plot coordinates on a graph using a mouse but i can't get it to wire up properly. If you could have a look and get back to me it would be massively appretiated.
(3,288 Views)
Anyone got any ideas? or currently trying something?
(3,259 Views)
The problem with the mouse click example is simple - you are using the incorrect event. Don't use the timeout event when you want to detect a mouse event.
(3,252 Views)
how do you change that? could you show me what it should look like please?
(3,243 Views)
Recneps,
You already have individual threads running on both these topics. Please don't open multiple threads for the same question. You can always post a 'bump' in a thread to keep it visible.
(3,241 Views)
(3,206 Views)
