Can someone explain how we can add two sine waves in labview?
I want to learn how to use labview. Am having trouble completing the block diagrma to add two sinewaves. Can someonle please explain how it has to be done.
(6,330 Views)
You could use the merge signals or the append signals function depending on what you want to do.
(6,325 Views)
The "Add" function has always worked for meSmiley Wink. What have you tried and what exactly is the problem you're having?
(6,320 Views)
