Can not get Call Library Function Node working
hi, Sorry to interrupt you in the middle,
     When I specify my Library path , I should get the List of function Name. Unfortunately I did't get any function from the class .Can You please explain, why I am unable to get the Function Name.
My ZWave.dll is from C# code.
Best Regards.
strapuda
Message 11 of 16
(1,052 Views)
That's OK. But why?
Posting a new question will be better for everyone... This thread has been solved, so will only get attention to subscribers.
Best guess is that you're exporting C# functions, and not C functions. LabVIEW will not resolve C++ (and probably C#) function names. Those names are only meaningful to the compiler the library is build in.
It could also be that you're building a C# assembly, not a standard DLL. If so, you should open the assembly as .NET object, not as a CLFN.
Message 12 of 16
(1,049 Views)
Because your DLL is not a normal Windows PE DLL but a .Net assembly instead. .Net assemblies do not export any functions like normal DLLs. Instead you should use the .Net function nodes in LabVIEW to reference to your .Net assembly DLL.
Rolf Kalbermatter  My Blog
Message 13 of 16
(1,042 Views)
Presumably, because it does seem possible to make a PE DLL in C#...
Message 14 of 16
(1,034 Views)
Very unlikely though and then you would almost certainly have an exported function. Pretty hard to compile a PE executable module without any public exports without at least some warnings. And AFAIK you have to bend backwards and stand on your head to convince the C# compiler to do that.
Message 15 of 16
(1,029 Views)
Agreed.
Message 16 of 16
(1,023 Views)
