Can i get 10000 samples/sec through communication
RANA
(3,100 Views)
Accepted by ranacullen
Yes.
(3,044 Views)
Can you please post a sample vi for reading the above mentioned tcp/ip specification
Thanks in advance.
RANA
(2,998 Views)
Hi rana,
there is no "TCP/IP specification", it's just a table presenting the max samplerate depending on some parameters…
You need to read the whole device manual to create a device driver!
(2,987 Views)
This is the only thing in the datasheet about the communication that the manufacturer has provided. Can you be more specific on what are the details I have to gather from device manufacturer?
RANA
(2,983 Views)
Hi rana,
which protocol is used? Modbus/TCP? HTTP POST/GET? LXI?
Does the manufacturer provide any example software? Any LabVIEW drivers?
(2,975 Views)
Okay will try gathering these data and get back.
Thanks a lot.
RANA
(2,971 Views)
