Can i build an application with Labview 2009 for Windows 7?
Hello
i use Labview 2009 SP1 and the application builder 2009 SP1. If i install the application on win7 this message is display:
Labview Run Time Engine depends on pruduct with upgrade code (...) version 9.0.301, language {} which is not in distribution.
(2,666 Views)
Are you trying to install/run the application on the same computer or another one? Dont forget to install the runtime engine.
/Y
Qestit Systems
Certified-LabVIEW-Developer
(2,660 Views)
The application running on my computer and on another computer with xp.
(2,651 Views)
Accepted by MOBA-User
Is this an issue with Windows 7 having both installation folders for 32 bit (C:\Program Files (x86)) and 64 bit (C:\Program Files)?
I had an application built on an XP machine and installed on a Windows 7 machine which was looking for files in C:\Program Files when they were actually installed in C:\Program Files (x86) - because it was 32-bit application.  After installation I had to move the files from 1 location to the other to make it work.
(2,642 Views)
