Can i Have Delta ASDA-A2 LabVIEW driver to control servo motor
Can i Have ASDA-A2 LabVIEW driver to control servo motor? there was library in VIPM but it doesn't any more
CLA
(385 Views)
Here is the one on vipm.io
SDI Plug-in - Delta ASDA Toolkit for LabVIEW - Download - VIPM by JKI
Santhosh
Soliton Technologies
(362 Views)
Hello Santo i have tried this site different time but it didnot download , do you have copy of it or can you download it ? so may i do it wrong?
CLA
(310 Views)
Hi Ahmed,
I've attached the VI package file for you.  However, this package requires NI SoftMotion to run, but NI has discontinued the SoftMotion product.  Also, you'll need access to a cRIO controller to serve as a EtherCAT master, as this plug-in only supports Delta ASDA-A2-E EtherCAT drives.
For a more modern solution that can control Delta ASDA-A2 drives from LabVIEW, see this video: https://www.youtube.com/watch?v=vVT29MvLhtE
The TENET EMotion board can control any Delta servo drive that has a PUL/DIR input interface.  We've also specifically designed a "one-cable" solution, so that the wiring connection from PC to Delta is as simple as possible.  If you're interested, you can leave a message on our website to get more information.
BR
John Wu
TENET Technologies
Add motion to LabVIEW in 30min or less - TENET EMotion
Finding it hard to source legacy NI hardware? Try Extend Test
(278 Views)
I have tried your attached version of sdi plug and already searched for it in VIPM but not running ? so is their any other solution , can i control via any kind of communication protocol
CLA
(270 Views)
