Can anyone help me to resolve these error in LabVIEW PDA module
These are the errors that i have encountered when i am programming in my LabVIEW PDA module.
_GetConfFormate is a missing VI or C file
_GetConfState is a missing VI or C file
_SIConfigure is a missing VI or C file
Can anyone solve these error?
(3,170 Views)
Hi student G
THere have been arrors posted that have to do with a localized decimal point, but
it doesn't seam that it is in your case.
Am I right if I considder that you are trying to use C code in ypor project?
If this is correct then I would recommand to try to write a very simple example.
This could be something like:
int func (int a,b)
    return (a+b);
This is a primitive example but you can try to add it into your project.
If you can compile your project with this call library function than
you have configured your project correctly.
Once everything works in this pwimitive way you can enhance the
C file and try out where the mistake in your code is.
In many cases the C code is correctly enough for visual C++ but
it itn't correct enough for the C compiler that is behind the PDA
toolkit. The failur output from LV is in many cases not worth to have
a look at it, bcause it doesnt help you in any way. The failure can
be caused by another instance too.
The
With kind regards
Martin Kunze
KDI Digital Instrumentation.com
e-mail: martin.kunze@digital-instrumentation.com
Tel: +49 (0)441 9490852
(3,145 Views)
Hi student G
int func (int a,b)
    return (a+b);
The best
With kind regards
Martin Kunze
(3,145 Views)
 Hi there
Do you know where to put this C language which you suggested? Like in which part of LabVIEW. Thank you for your quick respond.
(3,133 Views)
Hi Student G,
Are you using a C DLL like Martin hypothesized?  If so, this KB should help you successfully include the code:  LabVIEW PDA Module Build Errors with VIs that Call DLLs.
Hope this helps!
Megan B
(3,113 Views)
thanks i will try it out
(3,095 Views)
