one help me how to connect a stepper motor and solenoid to a pc so that I can monitor the responses, maybe by plotting up the graph.I know that I need to use labview but how I can do it since I'm very new to this environment. can labview plot up the graph?I'm not sure what response you intend to measure, but you will need a transducer capable of measuring the response. You will then need a
Data Aquisition Card to aquire the data. Depending on the type of transducer you have you may also need some
Signal Conditioning.
If you wish to run the stepper motor from LV you will want to use our
Motion Control and Motor DrivesPlotting a graph is what LabVIEW does best! Learn more about LabVIEW in the
LabVIEW Zone.
Our sales representatives are ready to disscuss your project
and help you meet your goals. Please don't hesitate to
Contact them.
Amaury
NI Applications Engineer.
