Can an output data generated within a loop in a sub-vi be transfered to the main program for each iteration of the loop ?
@Zekasa wrote:
Or does it mean that I have to write to the global only once?
Do a search on "Worm" global
Message 31 of 36
(1,267 Views)
Thanks Ray,
I was Smiley Mad when I saw ur reply I became Smiley Happy.
I will see the Gloabl worm, and hope to get more understanding.
thanks
Message 32 of 36
(1,263 Views)
Zaki,
There's no need to get angry..  I still learn many things from this forum.  Expertise is a relative word..
Just do your thing, have fun, share & learn.
And it's okay to get upset every once in a while... Otherwise, we wouldn't be human, would we?  😉
Cheers,
RayR
Message 33 of 36
(1,251 Views)
Below you will find a link to the Worm Global.
Queues are fine and dandy, but I'm surprised nobody mentioned using a reference.  Queues are probably quicker, but its worth looking into the reference solution.  In the two attached VIs, the main calls a subvi.  The subvi runs a loop where a variable changes on each iteration.  That change is displayed in the main as it happens by using a reference and the Value property node.  Property nodes are slower than queues, but the coding is simpler.
- tbob
Inventor of the WORM Global
Message 34 of 36
(1,244 Views)
Hi tbob,
Thanks very much for your message. I will evaluate the possibility to use references. It looks easier indeed.
Thanks for the examples, that's reaaly nice to have a direct reading of an illustration of what you propose.
Thanks a lot.
I'll try it.
Cheers,
yoyo87
Message 35 of 36
(1,234 Views)
References are fine as long as you do not need to synchronize between when data is ready (available) and it reads only new data.  If you pass only a single data, then a Notifier would also do the trick.
There are many choices to choose from.  It usually depends on exactly how you want the sw to behave.  Which brings another topic (that I gave up within the forum), which is "designing the software".
Message 36 of 36
(1,223 Views)
