Can an Labview Executable file run automatically upon the boot up of a CPU?
I wanted to use a PC/104 to run a LABView.exe file.  So I have two quetions can a Labview .exe program be written so that it dosent need the start buttn pressed to activate it, it just runs upon execution.  And the second is that once the PC is booted can it be configured so that the .exe automatically starts?
(3,282 Views)
You could build your VI into an application, and add the .exe to your startup menu that shows up when you type "msconfig" into the command prompt
(3,281 Views)
Here is a KnowledgeBase article that I think will be helpful to you as well. Have a great day!
Amanda Howard
Americas Services and Support Recruiting Manager
(3,245 Views)
Are you asking at boot up or login. If you are asking about login, there suggestions will work. At bootup, you will need to make the exe a service to start.
(3,233 Views)
