‎06-04-2009 02:57 PM
Can a global variable be set to a boolean value in LV3.1.1? I can do it in LV 8.0, but 3.1.1 which I need because of instrumentation factors is giving me trouble.
Any suggestions from long-time users?
‎06-04-2009 03:09 PM
Well, I'm a long time user, but that's going back quite a while. ![]()
A global variable is basically a VI without a block diagram, so you should be able to place a Boolean control on the global variable just as you can place a numeric control. Booleans were treated differently back then, but it probably won't affect what you're doing. Are you saying you've tried, and you can't place a Boolean control on it? I honestly don't recall this being the case, but if it is, you can always use the functional global construct, which is what we did before global variables were introduced.
‎06-04-2009 03:54 PM
‎06-04-2009 05:14 PM
‎06-04-2009 05:16 PM
