10-02-2009 04:19 AM - edited 10-02-2009 04:20 AM
Hi guys
I connected a NI USB-9219 4 channel universal analog input module, your standard 4-20mA, and a DAQ assistant in the vi attached.
However that day due to some reason (solved now) I could not build a installer file with NI-DAQmx8.8 additional installer as below:
Thus because the setup file was required urgently I used the instead the traditional N1-DAQ7.4.4 instead to replace the N1-DAQmx8.8, and successfully build the installer file
Now I dont have a N1 USB 9219 to test if my installer file (with the N1-DAQ 7.4.4 binded and no N1-DAQmx8.8 binded) works or not, so my questions will the N1-DAQ7.4.4 works with the DAQ assistant in the vi attached as well as N1 USB 9219?
Advance thanks.
Solved! Go to Solution.
10-02-2009 06:45 AM
10-05-2009 04:45 AM
