Can I use scan interface mode when collecting data from cRIO? How do I display the continuously collected data on a waveform graph?
@gleekd wrote:
... no data file was created even though I specified the path in the property window to be on Desktop, for instance.
There's your problem, I imagine.  The path most likely needs to be local to the cRIO
Tim Elsey
Certified LabVIEW Architect
Message 21 of 23
(973 Views)
Accepted by gleekd
I was a little off with that last reply.  You can put whatever path you want, but the cRIO will turn it into a path on the cRIO, it won't actually save it to that path on your host machine.
I just successfully ran code with a Write to Measurement File on my cRIO 9025.  The file was configured in the node for C:\TestData\test.lvm.  The code is smart enough to automatically convert that to /c/TestData/test.lvm on the cRIO.
I think your problem is that you're looking for the file on your desktop, since that is the path that you entered.  If you go to ftp://cRIO.ip.address, I think you will find that the code has generated a file path that mirrors the path to your desktop, only it will be on the cRIO.  (I have just confirmed this on my 9025)
The first red arrow shows that I have ftp'd into my cRIO
The second red arrow shows that my code has generated /c/TestData and the .lvm file within
The third red arrow is the path to "my desktop" that the code generated, when i selected my desktop in the Write to Measurement File vi
Tim Elsey
Message 22 of 23
(962 Views)
Awesome!  Thanks, Tim!  This answer has solved my problem!
Message 23 of 23
(952 Views)
