Can I set autoscale to ignore zeros?
Hi all,
I have an array that is updated in a loop. In order to save memory, I don't build it in the loop but define the size in advance and use the replace array subset VI. This results in a 2D array of zeros and data. I would like to autoscale the data part and ignore the zeros (that aren't really data).
For example, my array starts as a 100x100 array of zeros. Then lines are updated with values between 6 and 7. I would like the scale to be between 6 and 7, and ignore the zeros.  I tried playing with color tables, but I need something that will change as new lines are added, so that if the 50th line has an 8 in it it will also be seen.Is this possible?
Danielle
"Wisdom comes from experience. Experience is often a result of lack of wisdom.”
― Terry Pratchett
(2,609 Views)
Accepted by dsavir
Try initializing with NaN.  NaN values are not plotted on a graph.
(2,596 Views)
This works great, thanks!
Danielle
― Terry Pratchett
(2,570 Views)
