Can I send a 'Built' application to someone with new hardware and have it work without having to load all of the software? This is DAQmx application.
I have a completed, working LabVIEW 7.1 application.  It is 'Built' as an executable file.  If I have a long distance user buy the required NI hardware, will my exe file recognize the front end and work?
Ron
Message 1 of 8
(3,531 Views)
The LabVIEW runtime engine is available for download from NI.  So you can send the exe files and they should work fine.
Depending on the hardware and the code you might have them set up the hardware using MAX or a Max configuration file.
Not sure what you mean by "front end".
Mark Ramsdale
Message 2 of 8
(3,527 Views)
You should be able to create an installer that automatically includes the everything needed to run your applicaton.
Exported MAX configuration
LabVIEW Run-Time
DAQmx   Run-Time
MAX
Message 3 of 8
(3,520 Views)
The exported Max config file is most probably my problem.  I have sent them the RunTime engine adn the executable.  I think I understand.  I need to send them the Max config files.
Thanks!
Ron
Message 4 of 8
(3,517 Views)
One question on the MAX.  The user on the other end has to run that and then create the MAX configuration, correct?
Message 5 of 8
(3,510 Views)
You can export your DAQmx configuration and then have the installer run the import for you automatically.  It works fairly well in my experience.
Message 6 of 8
(3,507 Views)
New versions of the application builder allow you to set up the installer to automatically import the inluded MAX configuration.  I've never run the version that you are using so I can't say for sure.
The general idea is to get the NI hardware and drivers installed on the target PC, make sure that the device is named the same as it was on the development machine and then import the MAX configuration.  At this point your .exe should be able to run.
Message 7 of 8
(3,505 Views)
