Gah. The tilt wheel mouse has been in use by LabVIEW users (judging by
the old messages about this I've found) since 2001. However, every
solution for "Can I scroll horizontally, please?" is "Hover over the
scroll bar and use the regular scroll wheel."
The whole point of having the tilt is that you *don't* have to move
your mouse away from what you're doing (working on your front panel or
block diagram) to go hunt down the scroll bar.
This is a *huge* usability win in spreadsheets, and it would be for LabVIEW as well, were it possible.
We're encouraged to write code left-to-right, so why do we not have a
way to move around it without having to stop what we're *really* doing
to go find a scroll bar or (in LV 7.1) a navigation window? (And don't
tell me about auto-tool either: even with "Ctrl to swap to
second-most-useful-command" it still doesn't go to a text edit cursor
over string constants (LV 7.1.1), which kills its usability for me.
Thus I can't use its Ctrl+Shift == "hand to grab your diagram"
function.) I understand NI's decision to write their own scroll bar
control for cross-platform purposes, and I would agree that it's the
thing to do in this situation, but that means LabVIEW's scroll bar (for
better or for worse) is expected to *act* just like the ones in every
other windows application, since it *looks* like the ones in every
other windows application.
So, two proposed solutions:
- Tilt Wheel Support
- Add the open hand tool to the cycle that gets tabbed through when
you're *not* using auto-tool. (or tell me where I can add it myself.)
LabVIEW is a great tool, but even the best tool is annoying to use if you get splinters every time you pick it up.
