Can I scroll horizontally without having the pointer over the scroll bar? Please?
Gah. The tilt wheel mouse has been in use by LabVIEW users (judging by the old messages about this I've found) since 2001. However, every solution for "Can I scroll horizontally, please?" is "Hover over the scroll bar and use the regular scroll wheel."
The whole point of having the tilt is that you *don't* have to move your mouse away from what you're doing (working on your front panel or block diagram) to go hunt down the scroll bar.
This is a *huge* usability win in spreadsheets, and it would be for LabVIEW as well, were it possible.
We're encouraged to write code left-to-right, so why do we not have a way to move around it without having to stop what we're *really* doing to go find a scroll bar or (in LV 7.1) a navigation window? (And don't tell me about auto-tool either: even with "Ctrl to swap to second-most-useful-command" it still doesn't go to a text edit cursor over string constants (LV 7.1.1), which kills its usability for me. Thus I can't use its Ctrl+Shift == "hand to grab your diagram" function.) I understand NI's decision to write their own scroll bar control for cross-platform purposes, and I would agree that it's the thing to do in this situation, but that means LabVIEW's scroll bar (for better or for worse) is expected to *act* just like the ones in every other windows application, since it *looks* like the ones in every other windows application.
So, two proposed solutions:
- Tilt Wheel Support
- Add the open hand tool to the cycle that gets tabbed through when you're *not* using auto-tool. (or tell me where I can add it myself.)
LabVIEW is a great tool, but even the best tool is annoying to use if you get splinters every time you pick it up.
(3,013 Views)
I cant comment on the tilt wheel comments as I dont have one on my mouse.  But I recommend the auto tool Smiley Happy What works for me is using the auto-tool and if you need to edit something (like a string constant) double left click in the strings main area and it will go into edit mode.  Just an FYI.  Sounds like a good suggestion to me
(3,007 Views)
Ahhh, that works. Thanks for the tip!
Edit: It doesn't change my desire for a working tilt wheel in LabVIEW, but it'll (hopefully) suffice until such functionality is added.
Message Edited by batesbc on 09-15-2005 09:44 AM
(3,004 Views)
I strongly agree. Using the wheel to scroll up&down is much easier than using the scroll bar.
Most mice allow you to push the wheel down to achieve the same effect that ctrl gives you now - if you press the wheel, you can move the mouse to get panning of the open window.
___________________
Try to take over the world!
(2,995 Views)
