Can I run code written in LabView on machines without the software loaded?
I am new to LabView and have purchased software with one license.  The radios I am writing scripts for are controlled by laptops, can the scripts I write be run from these laptops without LabView loaded to them?
(3,200 Views)
If you have the professional version of LV you can build EXE's and run them on the laptops. You still have to download and install the run-time engine.
Joe.
"NOTHING IS EVER EASY"
(3,192 Views)
If you don't have LabVIEW Pro, then you can purchase the application builder alone:
https://www.ni.com/en-us/shop/product/labview-application-builder-module.html
(3,162 Views)
Just want to add one thing.  If you build an exe using Vision Devp, you have to purchase a licence for each computer that will run this exe.  Each licence is about $100.
------- LabVIEW 2009, So Easy, Even a Therapist Can Do It -------
(3,152 Views)
Thanks for the info, I really appreciate it.
(3,137 Views)
On the LabVIEW CD, there is an option to install the run time engine. If you
install this on a PC, you should be able to run VI's, without the need to
build an application (so you don't need to buy the application builder).
Wiebe.
(3,107 Views)
