Can I export descriptions & tip strips?
If possible, I'd like to export all the context sensitive help descriptions & tip strips I've written to document my various controls. Some of the same text could be used in our printed documentation.
Is there a way to export all the user help info embedded in a vi without lots of cutting and pasting?
Message 1 of 9
(4,119 Views)
You can do this programmatically using property nodes. The Tip and Description are both properties for any controls. Take a look at this example.
Message 2 of 9
(4,119 Views)
Great idea! I'll try it today.
Thanks!
Craig
Message 3 of 9
(4,119 Views)
I tried blimpie boy's suggestion. It is/was a great idea. Unfortunately, it doesn't quite work for my application. My used interface has almost all the controls placed on different pages of a tab control. The reference created by the panel and control property nodes is only for the top level controls. So I get references for my tab control, but not references to the (many) controls embedded in the tab control.
Is there any way to wire the reference to get access to the individual controls on the tab control?
Thanks again, Craig
Message 4 of 9
(4,119 Views)
I have the same problem getting the descriptions of individuals controls inside a cluster.
Anyone have a resolution
Message 5 of 9
(4,119 Views)
Yes, there is a way. See the attached extended version of blimpie boys original VI.
-Franz
Message 6 of 9
(4,119 Views)
Unfortunately I am lock into Labview 6 for this project and cannot open the file.
Is it a LABVIEW 7 capability .. or can you describe the solution (or save in 6.1)
Message 7 of 9
(4,119 Views)
see attachment, the solution should not be LV 7 specific. But it's easier to see the VI than to describe it...
Message 8 of 9
(4,119 Views)
Perfect --- Thank you
Message 9 of 9
(4,119 Views)
