Can I create an executable file for 32 bit that was written in 64 bit?
Can I create an executable file intended to run on a 32 bit system that was developed in LV 64 bit?
(1,184 Views)
Accepted by topic author scott613
You need LabVIEW 32-bit to build a 32-bit executable.  But your code should just open in the same version of 32-bit LabVIEW and 64-bit LabVIEW.
GCentral
(1,166 Views)
As long as you build it using the appropriate development environment.
NOTE: third party dependencies like DLLs should also be 32-bit when you build (if you have any)
(1,162 Views)
