Can I create a matrix with empty elements?
I am trying to make a 3D plot of experimentally obtained data points. I understand how to set up the block diagram, but the problem is that I dont have a z data point for every combination of x and y. I need to make a matrix like this:
5   6   7   8   9   10   11
3        53     820       15
    45       35      57
25     34      57         48
5   6   7   8   9   10   11
Where the blank spaces signify no data was taken, so the matrix needs to have some type of 'greyed' cell.
If I try to do this now, the VI just inserts zeros in those places and I get an incorrect surface. If I put NaN in those spaces, VI plots the points, but does not connect them to make a surface.
Any suggestions?
Thanks in advance!
Luke
(2,576 Views)
Luke,
I can see two options:
1. Try to fill the voids by interpolation. Look into the interpolation vis.
2. There are methods that can plot such a so called 'scarce matrix'. Such a method basically accepts the data as a series of 3D vectors and performs a 2D curve fit. Typically 2D splines or B-splines are used as test functions. However, I don't know if this is available in Labview. Such code is available e.g. in the NAG library.
Cheers
Edgar
(2,561 Views)
