Can I create a kml file?
Greetings,
In many of my applications I record GPS tracks. At present I log the lat/longs every second to a csv file in degrees, decimal minutes (D M.MM) format as we move. I would like to simultaneously save this data as a kml file that can be immediately opened in Google Earth at the end of our transect. Is there a way to do this in LabVIEW? ( I am using 2013).
I know that kml files want the coordinates in the format of  long, lat, in decimal degrees (D.DDD) and I have already written subVI's to do this.
Karl
(5,578 Views)
Hi ,
     See to the below attachment , It solves your question.
kudos welcome 😄
Certified LabVIEW Developer
Best LabVIEW Programmer @NIDAYS 2015
(5,569 Views)
@smsanthosh wrote:
Hi ,
kudos welcome 😄
The red statement is a little overenthusiastic. You don't show in that example how to add the actual coordinates into the file.
Rolf Kalbermatter  My Blog
(5,563 Views)
Thanks for the quick reply,
So I am essentially creating an xml file...kml is basically the same I take it.
Google Developers show a file as shown below to create a GPS path in kml form:
If I used the constants as shown by smsanthosh in his example to write all the headers and jibber jabber, then add my coordinates as I receive them to the file, then close file when the transect ends, this should work I think.
Two questions; what is the open file icon with the O N in it in this example? I am not familiar with that one and can't find it.
Just by giving the text file the extension kml, does this make it a kml file?
<?xml version="1.0" encoding="UTF-8"?>
<kml xmlns="http://www.opengis.net/kml/2.2"> <Document>
<name>Paths</name>
<description>Examples of paths. Note that the tessellate tag is by default
set to 0. If you want to create tessellated lines, they must be authored
(or edited) directly in KML.</description> <Style id="yellowLineGreenPoly">
<LineStyle>
<color>7f00ffff</color>
<width>4</width>
</LineStyle>
<PolyStyle>
<color>7f00ff00</color>
</PolyStyle>
</Style> <Placemark>
<name>Absolute Extruded</name>
<description>Transparent green wall with yellow outlines</description>
<styleUrl>#yellowLineGreenPoly</styleUrl>
<LineString>
<extrude>1</extrude>
<tessellate>1</tessellate>
<altitudeMode>absolute</altitudeMode>
<coordinates> -112.2550785337791,36.07954952145647,2357
-112.2549277039738,36.08117083492122,2357
-112.2552505069063,36.08260761307279,2357
-112.2564540158376,36.08395660588506,2357
-112.2580238976449,36.08511401044813,2357
-112.2595218489022,36.08584355239394,2357
-112.2608216347552,36.08612634548589,2357
-112.262073428656,36.08626019085147,2357
-112.2633204928495,36.08621519860091,2357
-112.2644963846444,36.08627897945274,2357
-112.2656969554589,36.08649599090644,2357 </coordinates>
</LineString> </Placemark>
</Document> </kml>
(5,545 Views)
    Ya saving the text file to *.kml is enough. Once this menthod works for you post a reply to the comment....:)
(5,517 Views)
Accepted by KarlosAmigos
Well, that was a lot easier than I thought it would be!
I will have to do more coding to append my streaming GPS data to the file, but the basics are all there. In my attached VI, I have just used a constant with some coordinates from the Grand Canyon and it worked perfectly.
Many Thanks
Karl
(5,505 Views)
