Can I change background of program with a desired picture?
Hi
Can I change background of program with a desired picture? how?
Message 1 of 9
(3,701 Views)
Accepted by topic author behzad1
Hi behzad,
yes, you can.
Right-click the right window scrollbar (VI in edit mode) and select "properties"…
Other options:
- put that image on your FP (by drag'n drop) and move it to background
- put an 2d picture indicator on your FP and load the image at runtime into the indicator
Message 2 of 9
(3,696 Views)
Hi GerdW
tnx a lot.
that is OK, but
there are two simple problem, are these normal?
1) edit mode didnt find with right click, i found copy to clipboard from edit part. is it same? when I past picture, doesn't fit to all page. can I fit automatically?
2) when I use this picture, object cant be add to page with right click on part of page that has picture, and necessary to right click on out of picture on page. is it normall?
Best Regards
Message 3 of 9
(3,689 Views)
Hi behzad,
I really don't know what you are talking about now. Can you explain your issues with more details?
 Which LabVIEW version do you use?
When you embed a picture on the FP using the FP properties method you can tile or fit the picture to your FP size without any problems!
Message 4 of 9
(3,684 Views)
tnx,
I attached the picture, can it explain better my questions?
Message 5 of 9
(3,675 Views)
Hi behzad,
to requote my message #2: Right-click the right window scrollbar (VI in edit mode) and select "properties"…
What don't you understand of this?
When you don't trust me you should read the LabVIEW help on this topic!
Message 6 of 9
(3,671 Views)
Hi
actually no! I dont no where is scrollbar !
by the way, I use 2013 version.
Message 7 of 9
(3,662 Views)
Hi behzad,
I marked the scrollbar with a red arrow:
Message 8 of 9
(3,658 Views)
tnx a lot.
I'm really sorry!
I think I have some stress because of project!
Message 9 of 9
(3,653 Views)
