I want to generate a waveform to use the smart waveform
functions. Unfortunately the acquired data to build my waveform have variable dt. I do not only want to display my waveform (I know I could use a xy graph in this case) but I also want to do some calculations provided in the "Wavefrom Operations" palette?
Is there a way to achieve this except interpolating
the values along constant time steps on the x-axis?
Thanks in advance
Jochen
