Can I bring a control to front using a property node?
Is it possible to bring a control to the front (and send it to the back) via a reference and property node?
I've had a look but can't see anything obvious.
(3,292 Views)
I don't believe so.
If you think it would be useful, you could kudo this Idea Exchange entry:
Programmatic Manipulation of Object Layer (z-order)
(3,278 Views)
I guessed that it might not be possible. I used a work around with a Boolean button for the action and making the required control visible.
(3,255 Views)
