Gentlemen -
I can't thank you enough for your comments. I would have gotten back to you sooner, but I was having too much fun playing around with my newly-found labelling capability.
In playing around with "\" code method I found that I could embed high-ASCII characters (like the Greek mu symbol) in a wide variety of front-panel (FP) objects, but not all. Those that work include the following:
- FP string indicators and the default values of string controls
- Listboxes, Rings, and Tables
- Dialog string controls and indicators
- Dialog rings and listboxes
- Boolean labels, captions, and text via an attribute node
In some cases it is not possible to specify "\" codes directly on the FP. In those cases, it is necessary to wire a string constant on the Diagram to the attribute node. The string constant allows you to use "\" codes. Finally, I see no way to embed high-ASCII characters into the text entered on to the FP using the "Edit Text" tool from the Tools Palette.
I should also point out two more things. First, you need to have available a FP font that contains both the desired high-ASCII character and all of the standard alphanumeric characters. I see no way to combine characters from different fonts within any one FP text object. Secondly, it is the font that you selected for the FP object that rules; not the font specified in the Diagram. That's just the way it is. Hence, you can't concatenate strings with different fonts in the Diagram and hope to produce a combined font text string on the FP. Too bad.
As for the Alt-key method that Jean-Pierre suggested, I can't seem to make that work. Is this a PC / Mac difference? or is there a config parameter on my PC that I need to set for this to work?
Again, much thanks for the help. Boy, do my front panels look professional now. I guess I'll have think about the cross-platform issues associated with this labelling problem. Enough for today, though.
- Russ
