‎03-03-2006 01:15 PM
‎03-05-2006 04:16 AM
You should definitely use "LabVIEW" as library name and not "Labview.exe". The DLL executes in the context of the runtime engine and the executable of that is called lvrt.exe and not labview.exe. But LabVIEW has special treatment of the keyword LabVIEW in the library name of the Call Library Node.
@adambrewster wrote:
I have an application that used Call Library Function nodes to do some of its dirty work. The DLL file called uses a few manager functions for memory resizing and such, so it's linked against labview.lib as described in http://digital.ni.com/public.nsf/allkb/01BD203DE97AEBA986256800007546BB.
The problem is that when I create a build specification to make an executable that we can distribute, the application stops working because it can't locate LabVIEW.exe to load the manager functions. I tried rebuilding the labview.lib file so the DLL would look for the functions in the built application, but they none of the symbols were found and the application ended up with a broken run arrow.
How can a DLL access functions like DSNewHandle and Occur?
Adam Brewster
‎03-05-2006 02:50 PM
On second thought reading your question again, it may also be that you rather write your own DLL in something like Visual C and are using LabVIEW manager calls. In that case you should simply link your project with labview.lib from the cintools directory. The import loader in that library does account already for the possibility of the dll running in the runtime system and first tries to link to labview.exe and if that fails to lvrt.dll automatically. I know for sure that this works since at least LabVIEW 5.1 or so, so if you see something else then you do something wrong.
Adam Brewster
‎03-05-2006 04:33 PM
