Calling main vi front panel from sub vi front panel
Hi
In my project I have different sub vi's i need to call from main vi.
After the completion of sub vi task i need to return back to main vi.
Give some idea.
i attached my project with on sub vi.
hari
(2,983 Views)
Accepted by topic author thinnker
Open the subvi "Booster_Test.vi",
Navigate to
File -> VI Properties->select "window appearence in category", -> select "custom"option,click the "customize"  button and a new window appears
Check  the "show front panel when called " and "close afterwards if originally close".
This should solve your problem.
(2,975 Views)
You have a event structure to handle the buttons on the front panel.  Place the subvi in the event that should be called when the user presses the button.
Right click on the subvi>in the right click menu select "subvi node setup">>"Open the FP when called".   This option will force labview to open the FP of a subvi.
In VI Properties>>Window appearance>>"show FP when called" (select this option)
In the same window you have "Window Behaviour" - select "Modal"
These options will keep the subvi window on the top.  only the when the subvi is closed the main window gets the control.
Post back if any queries.
With regards,
JK
(Certified LabVIEW Developer)
Give Kudos for Good Answers, and Mark it a solution if your problem is solved.
(2,967 Views)
