Calling VI script from MATLAB
I wanted to run a VI script from MATLAB, and I looked up the Internet how to do so. I learned that if I used the following commands, I could run a VI.
e=actxserver('LabVIEW.Application');
vipath='c:\Documents\Labview files\test.vi';
vi=invoke(e,'GetVIReference',vipath);
vi.Run
But this gives me an error.
Error using
COM.LabVIEW_Application/GetVIReference
Invoke Error, Dispatch Exception:
Source: LabVIEW
Description: LabVIEW:  Open VI Reference no
longer matches VIs in memory by filename. A
filename is no longer sufficient because the
full name of a VI now includes any owning
libraries.
Error in readColorVI (line 7)
Does anyone have an idea what should I include apart from the file path to get the script running?
Message 1 of 8
(6,668 Views)
Does the script run correctly in the LabVIEW environment?
Chase
NI Technical Support Engineer
Message 2 of 8
(6,609 Views)
Yes, it works perfectly.
Message 3 of 8
(6,599 Views)
Is that particular test.vi using any calls to sub-vis ?
Message 4 of 8
(6,584 Views)
If it works in LabVIEW, I would follow The Math Work's instructions and create a ticket with them if that does not work correctly.
https://www.mathworks.com/help/matlab/matlab_external/run-external-commands-scripts-and-programs.htm...
Chase
Message 5 of 8
(6,569 Views)
The VI does call a sub VI, and that very well could be the problem. If there's a solution to it, I'd be glad to hear it.
If there isn't, then I'll raise a ticket at Math Works.
Message 6 of 8
(6,560 Views)
Accepted by DeepPars
The easiest way to find out is to eliminate the subVI call and see if it still errors.  If so, it's not the subVI
Message 7 of 8
(6,550 Views)
But what is the Win OS system command for running a VI?
Message 8 of 8
(6,034 Views)
