Calling NIST from Labview
Does anyone have any experience using NIST software with Labview.  I am wanting to call NIST to get properties of two different gases, and not exactly sure how to accomplish this.
Can anyone point me in the right direction?
(5,340 Views)
I use a TCP connection to get NIST time.  Not sure if something like this is available for what you are looking for.  Hope it helps.
aputman
(5,315 Views)
NISTime-32.exe is shareware and available here
Their is a command line hook so you can just call it with the system exe from LabVIEW
"Should be" isn't "Is" -Jay
(5,299 Views)
I guess that you want to use the NIST refprop library.
The NIST software comes with a DLL.
You can call the functions in the DLL by using the "Call Function Library Function Node".
In LabVIEW 2010 it is located in the functions palette under "Connectivity".
(5,283 Views)
(5,202 Views)
