Showing results forĀ
Search instead forĀ
Did you mean:Ā
Calling Dll Function
@rolfk wrote:
@MSS wrote:
Thanks Mr. Rolfk for your advice.
Where could  I get details about creating wrapper dll. is it easy to do. what are the things that I have to have to do that?
I'm afraid there is no ready made tutorial about wrapper DLLs because they differ greatly depending on the actual API you want to interface too. The first thing you will need is some good C programming knowledge. Without that it is obviously difficult to write a DLL but if you don't have that knowledge interfacing to such a DLL without wrapper is even harder.
The next step is about how to create DLLs (shared libraries) in general. This is explained for most C compilers that you could get, in the examples that come with those compilers. It's no black magic nor rocket science but mostly just following a few steps that can and will differ for each compiler to some extend.
What you want to do in a wrapper is writing a number of C functions that take more LabVIEW friendly data types (flat structures only with no embedded string or array pointers, standard C string pointers and array pointers as separate function parameters etc. etc.) and then inside those functions construct the more complex data types your real API takes. There are quite some (simple) examples about interfacing to external code in LabVIEW in general and getting these to compile and run first is definitely a good start.
You may now say but hey this is hard and I can't do that since I do not know how and all I can answer to this is that if you do not know how to do such a wrapper DLL you can never hope to successfully interface to the complex API data structures without exactly such a wrapper. So you will have to learn some C and learn how to write such a wrapper and then you can start to do it without wrapper although at that point you will likely find that trying to figure out all those nitty gritty details about structure size, correctly setting up the memory in LabVIEW to pass those parameters to the API function and all is way to troublesome, time consuming and also bad for future maintainability that you will not even consider not to create wrapper DLLs anymore expect for the most quick and dirty test cases.
Rolf Kalbermatter
I learned C. But I have no programing experience. That is why I have no idea about wrappinig. but I could Understand and program for it if could get some details.
Message 11 of 13
(798 Views)
Hi tbd,
As you suggest I will obtain the free compiler and try compiling the examples then let me update you the result.
thank you very much for your support
MSS
tbd wrote:
Hi MSS,
      Did your hardware come with programming examples?  If so, and they're in C, consider obtaining a C++ compiler (free.)  Get the examples working in C, then you'll be in a good position to "wrap" the functionality in a DLL for LabVIEW.  Once you know how to compile your examples, creating the DLL for LabVIEW will be a small step.  RIght now, though, it sounds like you have some learning to do!
Cheers
Message 12 of 13
(797 Views)
Did you succed in interfacing with Skuetek dll?... I need to do the same...
Emmanuel
Message 13 of 13
(667 Views)
