Calling C DLL functions
Hello
I have a VI that contains only a call library function node. This calls a DLL function to open an instrument, which will return if no instrument is found.
When I run it, it behaves as expected and the VI stops running. However, once it has stopped, LabVIEW will throw an exception and exit when I close the VI. Also, the splash screen that is displayed during the function call does not completely disappear; it reamains as an empty window until LabVIEW is closed.
I have tried the same call in C with no problems.
Is there something else that I should be doing to release the DLL, for example?
Robin
Message 1 of 8
(3,671 Views)
Hi RobinM2,
If you mine can you attached or snapshot of your program so I can figure out your problem.
regards,
Ludz
Message 2 of 8
(3,663 Views)
Hi Ludz
Thanks for your reply.
Here is an image.
Robin
Message 3 of 8
(3,653 Views)
We'll need more information than that. How is the Call Library Function Node function setup? Is the function supposed to be called using C calling conventions of stdcall (WINAPI) calling conventions? What is the prototype for the function? Is there an error generated by the Call Library Function Node function?
Message 4 of 8
(3,639 Views)
Thanks for the reply.
The Call Library Function node does generate an error. It (correctly) uses stdcall and runs in UI thread. The prototype is
unsigned long (short*)
Message 5 of 8
(3,614 Views)
How do you know this is correct? In fact, ...
The prototype is
This tells me it's C calling convention.
Clearly the argument is supposed to be a pointer to an integer. Are you passing the argument as a pointer?
Why don't you go ahead and post your VI and your DLL source code?
Message 6 of 8
(3,597 Views)
I have found that this only happens when using a debug DLL, there are no problems when using a release version. I'm not sure why this is, but it seems unlikely to be a problem on the labview side.
Anyway, thanks for the replies.
Message 7 of 8
(3,566 Views)
This problem sounds like you have the wrong calling convention.  If you are using WINAPI, try switching to C calling convention, as mentioned by smercurio.  Typically, when you assign the wrong convention, the code will work up to the point where the return from DLL happens.  The stack is messed up and will cause strange errors, including Labview crash.
- tbob
Inventor of the WORM Global
Message 8 of 8
(3,507 Views)
