Call .net dll event in LabVIEW
Hi All,
Any one help me to understand C# dll event step and convert into LabVIEW. attached files (LV Source code, Supporting DLL) for your reference
C# code - Event step
private static void Instance_InterfaceCollectionUpdate(IEnumerable<IHardwareInterface> added, IEnumerable<IHardwareInterface> removed)
Advanced thank you
Prashant Vernekar
(3,368 Views)
You don't call events - you provide a handler (eg. your callback VI or the C# method snippet you posted) and the thread that executes the event will call it when the event is fired.
You have created a callback for the event, but forgotten two things:
  1. Your callback has no logic. It has parameters for the IEnumerables but you're doing nothing with them. The example Program.cs you provided contains some logic to display the added and removed items - you could replicate this in a number of ways (popups, passing data back to your Demo.vi etc.). Based on your Demo.vi, you already know how to enumerate the IEnumerable items.
  2. Your Demo.vi ends abruptly, so there's no guarantee the event is even fired. The example Program.cs you provided contains a loop waiting for 250ms before shutting down and exiting; perhaps try replicating that.
(3,324 Views)
Hi tyk007,
Greetings for the day.
Thank you for your replay.
but I'm getting some error like "System.ArgumentNullException: Key cannot be null.". attached error image for your reference.
Please help me, if i missing any configuration device manager before read device name.
Prashant Vernekar
(3,278 Views)
Accepted by topic author Prashant1991
.Net IEnumerator's are always initialized to point to the record previous to the first one, aka invalid. Same is true if you call Reset() on an IEnumerator.
You need use a loop and call MoveNext() first before you can retrieve a Current() value.
Rolf Kalbermatter  My Blog
(3,268 Views)
Thank you rolfk
now its working fine
Prashant
(3,253 Views)
