Call Options / Reentrant
I have a slight concern with a VI that's called many times as a GUI, but only one instance at the time. When i open the first instance it works properly and then i close that and open the next and my event procedure doesn't work. Few options that i'm concidering and what is the advantage of these.
To make VI reentrant.
To load VI for every call.
Or should my program work without these adjustments.
Message Edited by Englund on 07-30-2007 01:37 PM
(3,253 Views)
(3,253 Views)
Hi Englund,
Please post some code that demonstrates what you have tried that,
works
and
does not work
This will help us help you!
Just trying to help,
Ben
(3,237 Views)
Also,
can you define: being called multiple times..  ?
Do you mean they are running simultaneously in parallel (at the same time / or can run at the same time)?
or do you mean called multiple times as being in a loop, so called consecutively? (a number of times, but never at the same time)..
The way I read the following: "I have a slight concern with a VI that's called many times as a GUI, but only one instance at the time. ", it sounds like the VI does not execute multiple times simultaneously..  Thus I agree with Ben asking, what works and what does not work??
Message Edited by JoeLabView on 07-30-2007 10:28 AM
(3,231 Views)
I mean called multiple times, consecutively, never at the same time. It's makes modifying easier if the VI's aren't reentrant (just double click). Reentrant works.
I was just curious about the memory handling of VIs that aren't reentrant and are called multiple times and how they should be loaded into the memory (same time with caller, every time called, third option that i don't remember)
I know what solution work, but i would be interested in how a VI that's called many times with "different" data is processed in the memory, which is not set to reentrant. All the data that is in one instance should be "erased" from the memory when a VI is closed, if i have understood the memory handling correctly.
(3,209 Views)
