Call DLL function with pointer to complex structure
I try to call a function using CLFN. My problem is the parameters of the function I try to access.
Here is the function and his parameters:
typedef struct _BAR_INFO
    ULONG              dwSize;
    ULONG              dwFlag;
}BAR_INFO, PBAR_INFO;
typedef struct _DEVICE_INFO
    ULONG              dwBarNum;
    BAR_INFO           BarInfo[6];
}DEVICE_INFO, *PDEVICE_INFO;
DLLIMPORT int GetDeviceInfo(
    unsigned int      devID,
    PDEVICE_INFO      pdevinfo
    ULONG             i;
    if(devID >= DevNum)
        return PCICORE_DEVICE_NO_FOUND;
    if(DevTable[devID].DevHandle == NULL)
        return PCICORE_DEVICE_NO_INITIALIZE;
    if(pdevinfo == NULL)
        return PCICORE_INVALID_PARAMETER;
    pdevinfo->dwBarNum = DevTable[devID].DevInfo.dwBarNum;
    for(i = 0; i < pdevinfo->dwBarNum; i++)
        pdevinfo->BarInfo[i].dwFlag =
            DevTable[devID].DevInfo.BarInfo[i].dwFlag;
        pdevinfo->BarInfo[i].dwSize =
            DevTable[devID].DevInfo.BarInfo[i].dwSize;
    return PCICORE_SUCCESS;
 In attached file there is the Get Device Info.vi that try to access this function. The code crashes when the function is called.
I probably don't pass the data parameters correctly to the CLFN.
Thanks for your lights §Smiley Happy
(3,688 Views)
The VI attached
(3,687 Views)
Accepted by NewCLAD
A fixed-size array in C is equivalent to a LabVIEW cluster containing  the same number of identical elements, so you need to replace the array with a cluster. Also, structs are always passed by reference and the C function expects a pointer to a struct, so you don't need to unbundle. Pass the cluster directly to the function as a single parameter. Try the attached revised version of your VI.
(3,665 Views)
Thanks Nathan. Its working fine.
(3,640 Views)
