Call DAQ Assistant from Labview code
how can I call the DAQ Assistant Dialog
from Labview code, and also from a the compiled program with Labview runtime?
Now I can configure the DAQ Assistant Express vi inside the block diagram, but can not change it during runtime.
But the DAQ configuration is not static. The end user have to change it.
A similar dialog is used inside Measurement & Automation Explorer with a global DAQmx Task.
Can I call this dialog from Labview?
Peter
Message 1 of 10
(6,783 Views)
If you need to change parameters, you need to use the actual DAQmx functions. Then you can create/modify the task in MAX, your project, or the front panel of your VI. The assistant is not intended for anything except simple programs that do not change. The example finder is filled with code that uses DAQmx.
Message 2 of 10
(6,775 Views)
I know how to configure DAQmx tasks, channels ... by Labview code.
But I want avoid to redesign the same GUI of the DAQ Assistant.
Message 3 of 10
(6,768 Views)
Why would you think you need to redesign the gui? You already said you know about MAX. Just get rid of the assistant in your program and use the existing dialog.
Message 4 of 10
(6,758 Views)
I know how to use the low level functions from the DAQmx palette. But not how to call the DAQ Assistant dialog to change a Task.
Message 5 of 10
(6,745 Views)
You can't. Already said that.
Message 6 of 10
(6,740 Views)
You aren't reading the replies and what you're asking for doesn't really make sense.  If you understand the DAQ assistant is for simple tasks and the DAQmx API is for something more flexible, it doesn't make sense to ask how to open the API programatically.
What is your actual goal here?  It sounds like you want something similar in appearance for your users to have to work with the DAQmx API in the background.  Creating a similar GUI is trivial.  You've spent more time arguing about it on this thread.  So, I have a hard time thinking that's your task either.
What is it you're hoping to accomplish?
Message 7 of 10
(6,733 Views)
Ok. The DAQ Assistant cannot used inside a program. Only to configure the Labview DAQ Assistant Express vi, inside MAX and SignalExpress. Creating a similar GUI is not trivial if you see all the different dialog types.  But why reinvent the wheel?
Message 8 of 10
(6,719 Views)
You don't have to reinvent anything unless you want to. That's the whole point of using a task in MAX and calling that. Then you can use MAX's dialog.
Message 9 of 10
(6,693 Views)
Accepted by topic author Peter_S
There exists a solution to call the MAX DAQ Assistant from Labview code to create or change a DAQmx task: LabVIEW DAQmx Assistant VIs
Message 10 of 10
(6,655 Views)
