Calibration and PreScaled Values
There have been similar questions asked so far, but I haven't seen someone with the same problems I have, so here goes:
I'm trying to calibrate two load cells from Cooper Instruments (100 lb, LFS 260-100).  They are connected to an SCC-SG24 in an SC-2345 box.
If I look at the connection in MAX, it tells me that for both channels, the Mode is "On Demand", the Input Configuration is "NRSE", and the Max/Min Input Limits are +/- 100m.
The VI is a very simple one - the DAQ Assistant and two numerical outputs (in a while loop).  Each channel is set for an internal excitation source at 10 V (the Use Ex for Scaling box is checked), the scale is linear, and it's set at "Full Bridge".
When I run the Channel Calibration Wizard in the DAQ Assistant, I'm hanging a series of weights from the load cell and commiting the values for each.
Now, here's the problem - if I only use one load cell, the calibration goes fine, and everything works as expected.  Using both load cells, however, it only works if I do a very minimalist calibration (values at the extreme ends of the range), but if I try to get a more accurate calibration by including more values during the calibration, I get Error 200939, saying
"The Channel Calibration Scale Pre-Scaled Values specified is not supported, because one of the numbers appears more than once in the specified array.  Ensure unique numbers are specified in the array.
Channel Name: CustVoltage0
Property: AI.ChanCal.Table.PreScaledVals
Repeated Value: 0.000000
TaskName: _unnamedTask<A>"
I've tried recalibrating, I've printed out the tables of values, and there's not any 0.000000's in there at all.  I'm very baffled.  Any help would be most welcome.
Eric Martell
(3,042 Views)
Hello Eric,
This seems to be a bug in older versions of the NI-DAQmx driver, it was recently fixed in NI-DAQmx 8.3, which was released today and is available for download.
Let us know if you have any further questions or problems.
Micaela N
(3,024 Views)
