Calculations with long equations
Hello Everyone,
I am getting data from several sensors and I want to do calculations with them via Labview. The equations are long. Whats the procedure or method to do this?
Alexis Koulidis
Message 1 of 17
(5,422 Views)
Just implement the equations using LabVIEW code. Length is irrelevant.
If you tell us a little more about the problem, maybe we can give more specific advice. What does the formula do? How many inputs does it have?
Message 2 of 17
(5,403 Views)
Thank you very much for your reply. I am getting data from 4 sensors, and I want calculate an other parameter that combines the sensors data with some constants.
Initially I was thinking to do with several Numeric and to each part of the addition, subtract or division separate, but I want to do all the calculations in once..If it is possible
I am giving an example of the formula: X,Y,Z and C are my input data from the sensors and 120,12,50 and 30 are constants
A = (120*pi*X)/(12*Y) + (Z*50)/(C+30)
Message 3 of 17
(5,392 Views)
Personally, I find the Formula Node easier to read equations from (and therefore implement).  Others, like Altenbach, will go with the "pure" LabVIEW code (wire up all of the functions).
Message 4 of 17
(5,384 Views)
Accepted by topic author Alexis_Koul
Excellent.  A solution for everyone's tastes.  🙂
Bill
CLD
(Mid-Level minion.)
Message 5 of 17
(5,370 Views)
Your solution looks excellent. One last question if I may. In your VI you put the X,Y,Z and C that you can put the values. In my case, I will just connect my data output correct with the numeric?
-Alexis
Message 6 of 17
(5,276 Views)
Though, a quick test show the formula node is noticably slower, so depending on your requirements it might be needed to use the nodes.
Qestit Systems
Certified-LabVIEW-Developer
Message 7 of 17
(5,257 Views)
I'd like to see your benchmark and results.  I know the formula node will eliminate parallelism, but I have trouble believing it will be "noticeable" on a small equation like this.
Message 8 of 17
(5,249 Views)
I would turn what I showed you into a VI on its own with the controls and indicator connected on the Connector Pane.  This small block is then easily testable and reusable.  Your main VI will then just call this equation VI, wiring up the values to the right inputs.
Message 9 of 17
(5,248 Views)
10M loops yields ~700 vs ~100ms (formula node in other case). So no, it's not noticable in a single run. But as i said, if the requirements are such that'll run many times in a tight loop, a factor of 8 is noticable. 🙂
Qestit Systems
Message 10 of 17
(5,243 Views)
