Calculating RMS value of data samples in RT
Hi
Thanks for your reply.
In order to latch the present value until next value is calculated I should use a shift register right. I am not sure how I can use "result valid" boolean. Thanks.
Message 11 of 14
(908 Views)
Yes, feedback node or shift register.  you could also use conditional structure and global or indicator. Kind of hard to recommend without knowing more about what you are doing.
Stu
Message 12 of 14
(906 Views)
Did you mean case structure instead of conditional structure? Thanks.
Message 13 of 14
(893 Views)
yes, you could use a case structure to hold on to the value if it's valid, or to ignore it otherwise
Misha
Message 14 of 14
(879 Views)
