.CSV to motor via Labview
@MPCARTIST wrote:
Doing that.
Removing the frame, that works.
Moving the close port brakes it.
Breaks
Disable the autoindexing tunnels!
Message 11 of 19
(1,422 Views)
For a first timer, that took some finding.
Yayyyy, you win. Well done. Great teacher!
I have been trying to get Maya to get a motor do this for 10 years. WONDERFULL!
Thank You!
Message 12 of 19
(1,420 Views)
FYI It's generally frowned upon to mark your own post as the solution, unless, of course, you found the answer yourself.
Message 13 of 19
(1,395 Views)
Hi Mancho,
So, sorry. I had no idea. Can I undo?
This is my first time on the site. I thought that was what I had to do to say thanks.
That said.
Thank you very much for your help!
The VI did read the file, convert it and it controlled the motor. Straight lines work very well, but I do have a problem with curved splines, the motor judders. All my lines are curved.
Is there a way to smooth it out. This must be possible for other sliders to work. Like DittoGear.
https://www.youtube.com/watch?v=jNgCF_fm8JQ
https://www.youtube.com/watch?v=2p8vumeFiak
Message 14 of 19
(1,382 Views)
@mpcartist
No need to apologize, just letting you know.  I knew your intention. You just need mark the specific post (or posts) that you thought were the most helpful.  As far as your other issue, I'm afraid that's beyond my expertise, but others here may have some ideas.
Message 15 of 19
(1,378 Views)
I will post an try and get it right this time.
M
Message 16 of 19
(1,375 Views)
Double post
Qestit Systems
Certified-LabVIEW-Developer
Message 17 of 19
(1,370 Views)
1. R-click graph -> Visible items: Plor Legend
2. R-click each plot (it's expandable) -> Tick Anti-aliased
3. Profit. 😉
/Y
Qestit Systems
Message 18 of 19
(1,369 Views)
This is fantastic!
I just sent a post out asking for help on this.
I just did what you suggested and I will test later when I'm on the machine.
That is great!
FANTASTIC!
Message 19 of 19
(1,364 Views)
