‎09-29-2009 12:22 PM
Recently, we adquired a new CRIO 9112 chassis. Before this, our system had: CRIO 9012 controller, CRIO 9102 chasis and four digital I/O targets. We have substituted 9102 chassis for new 9112 one. When create new project, when add new target or device, no targets are found (existing devices) and if select new, only 9102, 9103, 9104 and 9101 are displayed. Which software or driver we need for add new chassis?
Thanks and regards,
‎09-29-2009 12:57 PM
Hi turboserver,
The cRIO-9112 chassis should have shipped with a note in it to tell you the required software version is LabVIEW FPGA 8.6 or later along with NI-RIO 3.1.0 or later. Let me know if you did not receive this note. You can also keep tabs on the supported software versions for CompactRIO Hardware on the following link:
Software Support for CompactRIO, CompactDAQ, Single-Board RIO, R Series, and FlexRIO Devices
Hope that helps.
Bassethound
turboserver,
As per this document: ftp://ftp.ni.com/pub/devzone/tut/crio_software_versions.htm
Support for the 9112 requires RIO 3.1.0 and LabVIEW 8.6
Sebastian
‎09-29-2009 01:00 PM
I suspect you have an old version of NI-RIO installed on your computer. You can check the version of the driver in MAX. I would recommend you try installing the latest version from the following page:
