CRC15 with LabVIEW
Hi LabVIEW Community,
Just to check if anyone did do a CRC15 VI calculation before using LabVIEW? Have been searching through the forums but didn't find any. I am currently tasked to develop a VI to calculate the Packet Error Code for the LTC6811 Chipset developed by Linear Technologies but I realize the Packet Error Code (PEC) is the same as the CAN bus for the first 15 bits, the only difference is the last bit which there is a 0 attached for the Final PEC. I have attached screenshots obtained from the datasheet below
Can any experts advise me on this situation, please?
Thanks!
(3,604 Views)
Hi cyongjed,
What have you tried and where are you stuck?
Why don't you attach your VI?
The manual is rather clear: you can handle boolean values in LabVIEW and there is a XOR function available…
(3,593 Views)
Hi Gerd,
Thank you for the response.
I have tried it out with a design of my own version of the VI, and have attached it in the reply. I am currently having issues getting the correct output for the PEC. For example, the PEC of 0x0001 (input DIN) will be computed as 0x3D6E as the final result, but I am getting otherwise.
Attached the bitwise operation for this in the post:
cyongjed
(3,546 Views)
Accepted by cyongjed
Here's what I came up with.  Hopefully, you have more test vectors to try this on to make sure it works.
NOTE: The extra Rotate Left With Carry is to get bit 14 from the PEC (a 15-bit CRC is kind of weird).
(3,516 Views)
Hi Cross,
Thank you for the assistance given.
I have a doubt here, why did you use 0x4599 instead of 0xC599? I don't really get this.
Hope to hear from you soon!
cyongjed
(3,487 Views)
You always ignore the top item in the polynomial, in this case the x^15.  In this case, it does not really matter since bit 15 is not used in the CRC.
(3,446 Views)
