CRC generator problem
Now I'll mention my first clue that some engineer had trouble speaking to the tech writer.  STX is not 7F.  Check your ASCII tabels people.Smiley Frustrated
"Should be" isn't "Is" -Jay
Message 11 of 18
(2,933 Views)
@JÞB wrote:
@crossrulz wrote:
This seems to work...
I have no Idea how you reverse engineerd that!  no XOR between Data In[i] and Remainder Polynomial.  Yeah, that's not a "CRC" in a strict sense.  but probably what got implemented.
My hats off to you my friend
Actually, that is the true CRC.  I have had that VI sitting around for many years (as in around 7 years now).  All but a few that I have seen on these forums follow this paradim perfectly, with just a few parameters for variations.  I used this site for reference when I originally made up my CRC library: http://zorc.breitbandkatze.de/crc.html
Message 12 of 18
(2,929 Views)
That just points out the problem.
You cannot recover the corrupted Data without adhering to the math of a CRC.
Message 13 of 18
(2,912 Views)
Correct.  A CRC is nothing but a fancy parity check (used to verify the data is correct).  If you want to recover data, that requires something like Reed-Solomon and/or Hamming algorithms.  Most things just use the CRC and report an error if the check failed.
Message 14 of 18
(2,900 Views)
Exactly. Yet, claiming its a CRC is disegnuios. It fouls up developers.
Message 15 of 18
(2,880 Views)
This seems to be it!!
I tried to recreate this from picture but unsuccessfully. Can you please post vi (I'm using LV2010)?
Message 16 of 18
(2,860 Views)
Accepted by SuperbrainBug
Sure...
Message 17 of 18
(2,841 Views)
Sure...
I works! I want to thank everyone for help especially to crossrulz.
Message 18 of 18
(2,823 Views)
