CONFUSION TO SELECT TERMINAL CONFIGURATION
Hi, I'm novice in LabVIEW & DAQ. If my maximum and minimum value is +1 and -1 of Signal Input Range then what I have to select in Terminal Configuration? Differential/ RSE/ NRSE??
Can you please explain in detail? Thanks in advance.
(3,118 Views)
The range is unrelated to the terminal configuration.
Have our read this? Note rse\differential is not something NI came up with. So other resources might help as well. Notice those hits on the NI site? Those are duplicate posts...
(3,101 Views)
